vale79
Hello! !
I have 4 similar tipping bars:
- 600n-i: 600 mm long, without roll holder
- 640n-i: 600 mm long, with roll holder
- 830n-i: 830 mm long, without roll door
- 840n-i: 830 mm long, with roll holder
I would like to give or remove visibility to the roll port based on the code, which I entered as a "code" parameter in the identity data, and which has the same value as the name of the type.
I put the visibility parameter in the constraints but I don't know how to write the condition to make it visible or invisible. I think it doesn't like the "-i" in the final part of the code (besides the non-existent syntax of my formula).
You know how to do that?
Thank you very much
That's right.
Thank you very much
That's right.
