revit architecture 2014 - quick access bar disappeared
  • Thread starter Thread starter cadrev
cadrev
hello guys, as I just said in the previous post I'm trying the new revit architecture 2014.
I have installed revit architecture 2014 in English (I have not found the trial version in Italian. on the community there is only "revit" but I do nothing about the tools of structures and plants) and then I used the language pack, to have the Italian version! I used it is closed! the next day starting it I noticed that the quick access bar had disappeared! It didn't give me the chance to find the icons found in the default bar. I had only the possibility to add new icons... but those that in theory had disappeared in reality were just not visible. I understood why trying to add the 3d view icon did not allow me to do so (normal behavior of an icon that is already present on the bar).
As a result I "repaired" the installation with the classic procedure of both setups, i.e. rac 2014 and the language pack! worked again but at the second restart same problem! reading a bit on the net I learned about the problems that can be caused by the presence on the pc of rac 2013. so I uninstalled it (problems in doing so I had to do so many steps manually including system logs). I repaired again the 2 setups of the v2014, but at the second restart again quick access bar disappeared.
Now I ask you, what can the cause be according to you, and if any of you are involved in such a problem.
maybe, did I miss something in the uninstallation of rac 2013? (according to me the language pack, I throw it there).
Can there be a solution? As the quick access bar for me is vital...I don't want to be forced to install the full version of revit! thus keeping me also the section relative to structures and plants (always if it works :wink: )
I wait for news... and thank you!
just go to %appdata%\autodesk\revit\autodesk revit {product name} 201x and rename or delete the uistate.dat file and then restart revit
