revit con apple
  • Thread starter Thread starter grandevela
of autocad there is a beta, you do not know when it will come out, of revit still nothing, but most likely it will be written also for mac. of course I am talking about the native versions for os x, if instead install them on win with bootcamp, turn like on a normal pc.
but performance is better or does not change.
what I want to know if I install win with bootcamp performance changes me fast?
identical to a pc with the same hardware, in some cases the application examined went faster.
So what do you recommend?
Can I get a mac without problems or can you suggest a pc to turn right revit?
If I can: it doesn't make sense to buy a mac and then let us go an app written per pc. Using a winzozz emulator is equivalent to using a pc. if it's just for revit I think it's not worth it. otherwise if you also use other sw (native mac) for graphics then it is definitely a recommended purchase.
Bye.
