revit interface
  • Thread starter Thread starter Mart
Mart
a gross problem rev I can't fix it.
I opened a file I was working on and I find a surprise: the interface is literally crazy.
the windows of the project browser and the properties have “invaded” all the screen, preventing me from seeing the drawing window.
After several attempts I can hook up the browser window to the side (as had been set by revit himself) and magically the property window disappears.
every time I try to access the properties (clicking on the icon or right-click) revit stops.
I ask for help. I can't work without property and I don't know how to do it.
specific that the same problem remains even if I open a blank file.
Bye.
I have the same problem, too. after entering some lights, I couldn't open revit properly. I thought it was a "bacus" of the file, but the property curtain no longer appears with any other project, and when I call it, the program stops. while restoring the software and also reinstalling it from head, it does not solve anything.. .
Thank you very much.
I was playing for the argument already solved when .. the consequence was nothing.... I think the best thing is to erase all the revit settings and make sure that the restores happen. do you know what the files to act on? I mean, are there any other registry settings to delete? Thank you.
p.s.: I'm waiting for assistance from the dealer, but I still haven't had any feedback... .
If you have w7 as os verify that the profile you use really has the characteristics of admin......some have solved by creating a new profile....other I don't know how to tell you.....you know that the problem can be resumed and that the procedure should still be re-executed. . .
the operating system is xp, on a machine is 32 bit, the other is 64.. I hope, at least this time, that you will be able to make a useful contribution. soon
We're still waiting for the dealer's support reaction, but kicking out here and there, I found a way to remove corrupt revit settings. this method worked:
it is about rename or delete the following logs (better the first, so in case it is restored).
(regedit.exe)
for 32-bit versions of windows xp, view and windows 7
• hkey_current_user\software\autodesk\revit\autodesk revit architecture 2011
• hkey_current_user\software\autodesk\revit\2011
• hkey_local_machine\software\autodesk\revit\autodesk revit architecture 2011
• hkey_local_machine\software\autodesk\revit\2011
for 64-bit versions of windows xp, view and windows 7
I stress that I'm not a programmer, so I can't guarantee anything, but now the software turns and the property curtain is back perfectly.
Hello!
hi I am new to the forum, I was reading your discussion about this revit problem, which I also have and do not know how to solve it.
I really don't know where to start, I can't understand the procedures described to solve the problem.
my operating system is w7 to 64bit
I can't work since yesterday with revit under these conditions.
:confused:
for the moment take the project browser and unplug it from the edge and take it out of the revit window
So you work:redface:
