iron72
Greetings to all.
I have created a revolutionary solid, only that now I would like to make a hole passing from the two parallel ends, I have created a cylinder that passes through to all the solid of revolution, only that by doing the command subtract I do not get the hole.
I tried to subtract the solid revolution with other primitive solid ball type, cube, etc... but the result does not change.
what can depend on?
p.s:allego qui il file
what can depend on?
