rhino e windows 7
  • Thread starter Thread starter ugobaggio
ugobaggio
Hello I tried to install the trial version of rhino service release 6 on windows 7 but I responded several errors the online guide disappeared and the initial window where you set the measurements for the drawing is completely white.
how can I solve these problems
I press that I already tried with various solutions that propose windows but no works hello thanks
strange, I tried windows 7 just the weekend just spent and rhino works.
I regularly use rhino4.0 with win7
"I regularly use rhino4.0 with win7"
I associate myself, but is it not installed on a laptop?
I say so because to a friend rhino did not save or at least, imported, exported etc.
and there was no way to "go."
Well, surely you'll have solved. but in case. .
I had problems, solved by installing the last sr of rhino...
I use rhino tranqullamente with win7. a friend of mine had visual problems, in the sense that it did not display certain windows or pop up plug in. After 1 and a half million trials, we've changed the screen resolution, and everything's back, but it's not your case. to tell you that not necessarily the problem is related to win7.
video and ram card? What operating system did you have before on your PC?
the problem had occurred installing rhino ex-novo in a new pc with win7, without having put him the service relase.. as I usually try immediately the programs I did not remember to update the sr..
