ricerca cad free
jim78b
Hello gratutito I found varicad seemed nice but to practical side if I open a dwg with retini with colors and gradients boring does not convert them right, leave aside the texts and then you can't do pdf, you know what is free beautiful like varicad that supports well autocad files? solid edge does not take snailed retinals and does not change the local blocks!...
but varicad had so many beautiful things! I saw him draftsight... is there a mechanical expansion? autocad I would like to change it a little I hate it, quota as he wants in the "empty"
If you've tried me10 doesn't promise if you're quoting the background and an error sound signal. Sometimes with many autocad snaps take points that don't come in... .
remove all snaps and use only the most appropriate ones, like from near a perpendicular, da fine a fine, da fine a perpendicular etc. you will see that you will not be wrong.
then do not put the odds very far from the points you beat otherwise you may have difficulty in automatically updating with the iron command... .
in revit the quotas work more bound to the objects that are listed, but with this system it is also much easier to lose the quotas....:biggrin:
But in my work it is much better a program like me10 sometimes deleting lines of autocad sheet does not erase the quotas associated with them so much that if from new design you make a quota, autocad quota something that I did not explain?
I do not see all these difficulties in erasing quotas along with the "associated" sheet lines, but perhaps I have a pc with a supersonic autocad.
I have the impression that you work with a very slow system, don't I? ...
You're wrong my system is fast. It happens in my drawings with a lot of odds that you release something. . .
comparing me10 to autocad is like thinking that a cruise ship (:biggrin: ) to a pilot.
They both have a hull, a propeller and a rudder. .
:smile:
Yes, yes, you explained. and I confirm. are different software, made to do a different job.
autocad shares the distance between two points, regardless of which they are. programs you say (not just me10) share elements. It's not a stand-up comparison.
think that with photoshop erasing quotas is even more difficult than with autocad. so? is autocad better than photoshop? Of course... if you use it to make technical drawings. . .
You told me the same modeling... Do I believe it?? ? :biggrin:
However, gbg also quotes the elements, in fact when exposing in dxf adds points to which to hook the quotas. Yes, that way of listing autocad is really barbaric. .
