risoluzione part
  • Thread starter Thread starter and
and
Hello.
what involves the lowering of the resolution of the part
from 1.0e-6mm
to 1.0e-3mm
the message that appears to me if I carry out work with a lower resolution what it entails?
"the resolution of the 'tubular' part will be modified from 1.0e-6 mm to 1.0e-3 mm. please check the highlighted elements"
Hello.
from 1.0e-6mm
to 1.0e-3mm
ciao, se I have understood that resolution serves to define "how many figures after the comma" you want to hold, if you put 1.0e-3mm you hold 3, if the part in question you had done before "smantting" gives you that message so that you be careful that maybe you are losing potentially important data.
According to you, you can work with the 1.0e-3mm resolution, since then the 2d boards with annotations are approximately 1.0e-2mm?
depends on your product, in any case 3 digits after the comma are micron, I think they can quietly suffice.
use cocreated for 10 years and working with imported mathematicians often igs and stp, to make them become solid I had to employ an infinite patience working with resolutions of order 10-6, sometimes I found an infinity of surfaces, practically I had to
Once the software technician made me try with the resolution 10-2 (not set by default in the minimum program 10-3) miracle!!!! the piece has been loaded already solid with very few errors = time saved also in the order of 8-10 hours of work.
Moreover, performing the 10-2 resolution project has never caused me any problem in the management of the products, sheet molds (tolerances in the order of 0.01 mm) in fact still work with this resolution.
The problem does not arise if you work only with parts created by you always with the same resolution.
try importing components and you will see the difference.
