rispolvero solidworks
  • Thread starter Thread starter falcorsv
falcorsv
Hello everyone,
I make the premise that I do not find solution to my search in the forum or am not able to find them and if someone can indicate the discussion I close it immediately. having changed work for a few days in the new company work with sw, but in the last 2 and a half years I used if.
with if I created my main set (usually the frame) at the end and this was the starting point for the assembly of the parts of the other assemblies and my main set the following options:
1) to make it reference (not parameterized between the various pieces but used only for assembly), in this way when I made the table this reference set had a suitable display with the border lines held and little marked by showing also those details that are generally not seen.
2) make it not visible at the top level, it seems clear to me and I do not dilute.
3) exclude it from the distinct also this seems clear to me.
while for the exclusion from the distinct I think I have found how to do it, even if it seems a bit slender I remembered simpler (so we accept advice), to the others and two questions I did not find solution, obviously if you can do it.
thanks to all
1 to make it reference you must set it as envelope.
right button on the part or together (in this case you have to do it from the features tree) property selections and in the bottom right tab you find envelope. this state automatically excludes it from the distinct and graphically presents it to you blue
2 is not clear what you want to get. not visible graphically? not visible in the distinct? Anything else?
3 always through the properties (see point 1). atention the distinct have different display settings (not graphics, but presence) of the assemblies
in solidworks exists multibody modeling and a frame not need to be built as a whole
Thank you very much, inviluppo was what I was looking for answers to everything I wanted, as I imagined in a single command there is everything. for me debate closed.
