roller counter with double chain for drag
  • Thread starter Thread starter Emc2
Emc2
Save I have to renovate a roller counter with tangential chain drag (unique chain that instead of wrapping the roll sprocket works only on some teeth and is resting on a crawling plane) the chain is from 1" asa 80 , for various reasons I would like to mount z=25 twin pinions and connect the various rollers between them separate chain clips. I cannot use the duplex chain pins because two flanked chains are not there, I wanted to know if there are specific pinions on the market for this function with a distance between the 2 crowns greater than a duplex or you have to resort to a triplex pinion leaving the central crown unused, or use other methods such as weld a crown with a central hole enlarged to a single crown pinion.
roberto
a triplex pinion must be used, leaving the central crown unused, or using other methods such as welding a crown with a central hole enlarged to a single crown pinion.
One or the other of these two is nothing else.
attention to the entire rollers, with the ring chain was not important, with the chain rings is instead a problem.
surely the intersection will be in function of the chain step taking into account that perhaps I have to insert curtains as I must avoid the single start of the rollers for gliding problems seen the heavy load that I have to distribute (>15t) that would severe on a single roller triggering a slip phenomenon .
certainly starting from a ring and moving to a multi ring is different. interest must be fair with the development of the chain. As for pinions usually or take the 3 pinions and provide the power station or store two distant crowns. to have an idea of distance look for rollers and you will see that there are measures.
