roof layering
  • Thread starter Thread starter lorenzo67
lorenzo67
Good day to all. before inserting this discussion, I took a look at the forum but did not find the answer it does for me. therefore, I cannot understand how to make visible all layers of the roof in model 3d; the classic "coupled roof" material, I only visualize it as a film on the face of the roof ecstasy and not a thickness.
I hope I've been quite clear.
Thank you in advance.
Bye, Tristan. I want that in 3d see the thickness of the roof stratigraphy, so that at the external stratigraphy I stick the textured and simultaneous cover. all because inserting the hoods with the structural beam command, the design is so heavy and slows down so much.
Thank you for the answer. Hi.
I don't want to give you a trivial answer, but the solution can be that you have the level of detail of the view set to "low".
You know, anyway, as he said, [MENTION=9930]sadan[/MENTION], the texture of the materials is flat. when you go to make a render you will never have the 3d effect of the plugs, unless you use the tristan method
try to create a roof with the thickness of the plugs, over the roof formed by the lower layers.
In this way you have both the thickness of the cap, and the possibility to make it protrude from the cover.
[MENTION=35546]Dark87[/MENTION]I tried with all the levels of detail, but it's the same. [MENTION=73255]giro_marky[/MENTION]I think it's an unorthodox solution. Imagine if I had to insert a skylight and after for any reason to move it, it would mean to delete the roof created for the plugs, place the skylight and create an egg roof!!!! .
the beautiful thing is, that by doing an assonometric split, you see exactly how I would like it in model 3d.
However, the whole was born of the difficulty of creating the plugs on the roof, because if there was a simple way of applying the plugs to the roof, we would not use all these artifacts. I think autodesk should consider this problem for the next versions that will come out.
Thank you for everything.
