ilari-marco
Good evening to all,
My problem is this....
I need to create a normal two-phalt rectangular roof. . . However, it is a renovation so the indications that I have are not the slope of the roof but, the measurements from the height of the rooms inside in correspondence of the intersection with the roof in the lower part and the intradox of the roof from the inside.... I have now begun to model with the perimeter roof but at the time when I want to make the heights of relief I find difficulty; especially because giving an offset for the height of the roof from the perimeter walls this takes it from the gronda... I've got it on the inside. vice versa if model without the gronda the height turns out with the offset but when I go to change adding the gronda the reference height returns to the end of the roof.... then... I tried to add points with a known quota, but this clearly changes my inclination and consequently the height in the intersection. ...
Can anyone explain to me in poor words how to act?
Thank you all!
(I'll have a little more understanding)
Thank you all!
