room view update
  • Thread starter Thread starter lattu
lattu
I never realized that in autocad (I believe in all versions) if you divide the working space into 2 or more squares and in one of these you want to see the perspective of a room inserted in the drawing, to the changes of the room itself (position or change of focal) the view does not update but is replaced with a generic perspective view showing the room in another position.
the only way to update the view is to access the views by name and reset the view of the room as current.
Is there a variable or faster procedure to make sure that the view of a room is updated in real time?
that I know you can not, if you move the room, even if as a result the view is changed by name, the new view still goes rCalled.
