rotary organ board
  • Thread starter Thread starter yago333
yago333
Hello, everyone. I write my first post to ask for advice to those who can help me:
I have to realize a system consisting of a fixed base on which rests a second base that must rotate 360°, with constant motion, supporting a maximum weight of 100kg.
Hello yago.. and welcome (maybe a small presentation and a reading to the regulation before posting questions.:mixed: :smile:).
then,
I don't see the connection between your post and this section. Maybe you're a student (or counselor as a profile??) but the subject exulates from the only university world. it was better to post it mechanical design.
Still,
the question asked so does not say anything; You will certainly need a "slow" system, but you should be more precise. How is it done? What's the point? what size does it have?
for the motorization you could fall directly to a gear motor, or with a toothed wheel "circular crown". . solutions can be many, but you need to know how the application will be.
posting a box helps a lot.
Mar
