tester
hi, I have a small question: if I have to move or rotate a 3d shape, how do I carry behind even the sketches that make it up? Thank you.
it is enough that you move the first sketch of the part on another floor, then all the other sketches, with its feature will go belowhi teseo, you are right, to move parts into a set I also use the couplings, which is definitely the fastest method, I just wanted to move into space a part that I had designed according to a certain system of coordinates, but for example, if for reasons of foundry I had to rotate the piece and change the orientation of the conica di sformo according to another axis, I could recycle the sketches used for the construction of the model, but as they already have left.
It's not true at all.it is enough that you move the first sketch of the part on another floor, then all the other sketches, with its feature will go below
you are right; Solid as soon as you make changes, to a moved body, I put it back to your point of origin and then the answer... don't worry nothing happens....at least until now.more or less the solution was already there... I tried to move and revolve a rather simple piece, then I changed a function by adding a conic, the program reported the piece in the original position, once the modification returned it where I had moved it, (with so much change), for reasons of time I did nothing else, so, I don't know with more complex pieces as it will go, but so I could already go well, hello.
