jim78b
how do I rotate a viewport with all the content? ? ?
you have to enter the window, activate it, align theucs according to the result you want to get, then from viewpoint selections 3d - plain-current view and the window content will rotate.how do I rotate a viewport with all the content? ? ?
always for info, to make it so the variable vprotateassoc must be set to value 1 (default value anyway).....just for info, in 2010 you no longer need to use this method, but just rotate the window with the wheel command and also rotate the content.
Good to know... .always for info, to make it so the variable vprotateassoc must be set to value 1 (default value anyway).
vprotateassoc
type: whole
saved in: user settings
initial value: 1
when turning a window, determines whether the view within a window is rotated with it.
0 When turning a window, the view inside is not rotated.
1 When you rotate a window, the view inside is rotated in order to correspond to the rotation of the window.
Note: After turning a window, vprotateassoc is set to 0 for the new windows created in the same layout.
