rotation around a point
  • Thread starter Thread starter Axel
Axel
Hello everyone, I need to turn a curve around a point, I would basically want to block the point around which to rotate the curve and then run the rotation of the latter, someone please would know that you would use with rhinoceros 4?!
command _railrevolve, where you select the profile curve (the trend) that you want to rotate around the point ), and then give it the axis...that is nothing but the point, extruded upward (§ or low ), to make it clear to rhino that you want to rotate that curve around an imaginary axis.
