rotation axis poor graphics
MARCOC
hi to all, I ask you something at the computer level, I have a set that when the roote with the mouse wheel, in rotation lowers the graphics quality, the bird of the lines the colors change and other cyse that dig the model, I tried to change skeda graphics passing from a painting 4000 to a k4000 and finally p2000, always the same result.
I ask you which hardwere component can improve this behaviour,
currently I have a t3600 processor e5-1660v2 16gb ram win10 64bit
charge certified drivers. then adjust the edge finishing settings in solidworks. try to load the axieme in light weight.
all updated drivers, identical solids set between the two pcs,light weight load and not,where I have perfect win 7,where I have win 1o na m....da
PCs are identical, one and one of the and one of the
That's weird because I replaced the s.o. from 10 workstations from win7 to win 10 pro with all updates and sincerely I see that I have less problems than before and even the pcs that were tired are reborn. You probably have non-optimal hardware combinations to handle software and model. you probably don't have to use the updated drivers but those certificates that maybe are 5 versions before. the dell works well and the lenovo does not? or the contrary?
the drivers I installed quli that mibpropone him with the diagnosis, what indicates that all the risirses are correct, and already 1 year that I have PC with win 10 and practically not use it because and too clogged compared to that with win 7
strange.. very strange....I have the same pc with dual boot 7 and 10 with the same programs installed and in my opinion 10 is much more responsive than 7 .
for graphic performance there is the graphics card. the hard drive being a storage drive affects the program opening time and its files if they are saved on the disk. do a test where solidworks doesn't fit to install the latest drivers, rub them off the non-certified response and test. at work I do not use certified drivers to take advantage of driver news. go to the site nvidia and download.
I have replaced the hd, and reisnstallate win10, missing problem.
Thank you very much
