westy
Good morning, everyone.
I just joined this forum.
I am employed in an engineering company and recently began to use inventor.
I am also practicing with the help of some colleagues who know how to use it better than me, however I am trying to understand the operation as much as possible alone and I am in front of things that I do not understand immediately.
more specifically I am working on an assembly that contains a series of metal fittings whose axis of the section should be oriented from time to time depending on an angle.
I should orientate the axis of sayings mounted on the bisector of a variable angle so that it is all symmetrical seen from above.
I don't understand how to do it; if there is an automatic command as it could be the align command of autocad.
Can you give me a suggestion?
thanks for any answers
