route duplication
  • Thread starter Thread starter zetadierre
zetadierre
Hello.
I wanted to know why, if I create a duplicate on path, it is not editable with filtered reference to other objects. I explain better: if I create duplicate on path with tot elements above, it shows up as well as I set it. but if you want to change the course or length of the path once created, click twice above.. I see the path editing window, but I can't see anything else in the drawing, so I can't change it! everything becomes white background in short and so I don't know how to refer to my changes. Thank you.
So, I know the tool "duplicates along the track" which, however, does not bind duplicate objects to the track but remain separate entities.
We must understand whether we are talking about the same tool :-)
I do.
Okay, I also have this command but it doesn't generate a parametric entity, so this time I can't help you. will be an implementation of the Italian version. :-)
I do.
Simply click the right button on the object and choose, in the context menu, the edit path (if you want to change the path) or change profile (in the other case). then enter the edit mode and you can freely change the chosen item.
actually it is a function present in the Italian version, but not in the English version.
Thank you, but that was not the problem. I can change the path, I know, but if the change window similar to that of the change of symbols opens in the path, it doesn't filter anything behind it, making it impossible to change it...
Now I understand better. Just draw a new path before entering the modality, then enter and replace it to the previous one. It is not so intuitive that having a direct interactive possibility, but that is a limit of vw. hopefully in the future will be improved.
excuse can you be + clear? How do I replace it?
draw the new track, cut it, change the parametric object by pasting the new and eliminating the old. possibly insert a 2d point at the start of the path before eliminating it, so you have a reference to correctly place the new one
I get it. A little slender! As soon as I have to play at that point I try. Thank you.
It takes a lot less to do that than to say it.
In general, if you did not move it from the point of origin, the paste works on the place (or, however, the paste in place is called in Italian).
I do.
