daxo
Hello, everyone.
for the first time I have to deal with 5 axes working issues continuously.
the particular that I have to realize is similar to a "helix" wrapped on a tree for an angle of 120°. the " propellers" that make up the particular are three and repeat with a constant angular step.
I have made the calculation of the tool path by caia v5-r20sp3.
from the simulator included in the cam package turns out everything ok.
I have performed the output of the processing strategies in apt furnace and I have provided to generate iso files through appropriate post processors.
verifying the cn file on board machine carrying out the milling cycles to "empty"
I have found an analytical in the movements, quickly, of connection between the past.
Now I'll explain.
the tool change the processing is positioned correctly in z;
activates rtcp by g43.4 wheel and board correctly; approach as expected; perform the first work pass and disengage correctly. Now the unexpected happens. the tool should, after having disengaged, reposition to the point of departure increasing of one step the pass through rotation of the axis c in anticlockwise direction to a safety distance :finger:.
In reality the tool after dising performs a rotation of the axis c and in simultaneous also a slight slash of the axis b in clockwise simultaneous abatement with the axis z and therefore "crossing" the piece
Obviously I would have destroyed the piece and at least broken the tool. I have examined the files iso to an expert who asserts that they are correct and that the problem and in some machine parameter.
the working center used is a die seiki nmv3000dcg with control msx7111iv (basis fanuc31i if not mistaken) with bascula (b) second axis y and rotating table (c) second axis z.
Is someone able to give me suggestions on which parameter(s) should I intervene? or if there are special strategies to be adopted in the output phase of iso files?
I have already tried to make output with only g1 within the iso files.
I have already tried to enable the function of inserting interpolated movements between the connecting passes .
everything was useless:frown:.
thanks in advance all those who want to give me suggestions with the occasion I offer cordial greetings
Bye-bye
Now I'll explain.
Bye-bye
