antoniman
hi to all, on indication of a friend I installed exportlayout already' expired (the expiry date is 22-09-2009) but' I found that if before using the command shift the date of the pc the command works perfectly, then the question is:
Can you create a lisp that automatically set the date before you run the command and then put it back in place?
Thank you:
Thank you:
