saldature
  • Thread starter Thread starter Ghirarduzzi.G
Ghirarduzzi.G
Since filtering for welds the 3d coming out are far enough in time I allow myself to open this new 3d with a couple of questions related to the same problematic.
  1. how do I make sure that welds are not obvious in the explosive view since they remain in the orginary position? (see attached image) I cannot unfortunately use the layer because if I turn off the layer it eliminates them from the whole table and not only from the view that I care about.
  2. In this case I have a welded frame quite complex and therefore I would like to make views where only some parts of the axieme are seen and not the whole together so as to put the indication of welding between those visible parts without the hindrance of the other parts. How do I do that?
Thank you and welcome.
3d = thread... is Monday, have patience...:biggrin:
1. That's exactly the best way I think: get off with the layers, you can turn it off for a single view.
2. simplified representations
in both cases, look good, because I think I remember that the arguments have been smoothed out!
open the table then to the left select settings or settings then in the window selections state level drawing (at the bottom). put the snag on both the options that there are in control status level and ok.now open the layer tree and click on the brake to the left. The views all light up in my case. choose the one where you want to hide something, click until it becomes red and turn off the others. Now choose in the layer tree what you want to turn off and when you found: right button always hide in the tree but in the empty right button: save state. You turned off what you wanted in one view. now you can start again from the french and trade with another view.
