vale31
I went from proe5 to creo2 and found some difficulty saving files in pdf format
when I save the files from prt to pdf the lines are so thin that if we did not pdf to 400% I struggle to see them and are light grey
if, however, except from drawing to pdf, the thickness is ok, but when in pdf I see the light grey lines (often) with or without zoom, while tolerances and other quotas I see perfectly black and the correct thickness
I tried to create the pdf_table_file in config pro but it doesn't improve so much. . .
advice?
advice?
