same position in all
  • Thread starter Thread starter Utente NX
Utente NX
These are the steps:
1) creation of an assembly
2) has created two arrangement (the default one with all components and one with some deleted components)
3) I have inserted a sub-assembly and coupled
4) when I move from one arrangement to another, the last sub-assembly changes position.
5) I tried to set 'same position in all' to this mask, but it tells me that I can't.
do you have any suggestions to prevent this sub-assembly from changing its position in the switch between the two arrangements?
using nx7.0 and tc8.1
I think you need to create the first configuration and save the arrangement, then create the second and do the same.
Then they shouldn't change their position.
ps. is it not that the sub-assembly puts it on some component that moves or disappears?
thanks matrix for the interest... you've still guessed something.
I give you an example of how it is our distinct structure that I try to replicate in nx to be able to export it to our management.
I press that he's not smart, but I can't do anything, the decision comes from above to structure the distinct so.
I give you an example with cars, so you'll find yourself more in tune with what I'm going to write.
Pretend you have a distinct thing like this:
main group fiat 500
1st level)
1st level)axle bolt
1st level)axieme 4 wheels
to be able to create the axieme axle bolt, I insert the axle and then I put on all the dice and screws.
I create a new arrangement and I suspect the axle by adding the 'reference' option for tc not to see it.
now when I insert 'the axial bolts' with the right arangement in the main axieme fiat 500 and I accoppio a 'assal axieme', I find all the screws in its place.
if I move the holes in the components of the axial, everything remains updated.
The problem is when I have to add a screw.
the insert and the coupling in a arrangement, but when I use the Arragement without the structure, this screw changes position.
I hope you understand.
Do you have any solutions?
main group fiat 500
1st level)
1st level)axle bolt
complicated to understand from a description.
I'm sorry, but I can't.
