sampling
  • Thread starter Thread starter folle76
folle76
Hello.
given a section of a component, known that in the xhatch-xcomponent mode if I want to have a x° and spaced y mm sample I have to make a "recover sample" to restore a previously saved sample. Is there any configuration setting to make it set a default sample? Thank you.
Hello I am newly used I create 1.0 m40 I wanted to bring a question
in an asm with more details if I do a section then I have to order samples
as a spatial value and angle to allow the distinction of details there is a parameter or a command or procedure to be able to do it automatically, with tink3 (photo allego) there is a command that automatically does it
another thing I wanted to ask you in the prt with a relationship weight=mass_.....
I go to put in the parameters the weight I recall then in the cartilage(the weight takes it from the material)
but if I have a set like I do the sum of all weights
I hope you can help me
