save and block by name
jim78b
in the new versions or after 2008 in autocad there is still the function published block in place and once you save you can do it save by name, I was very comfortable?
right-click change local reference and then when I save if I go in the name I can rename it , I had seen that autocad 2010 Italian had no more!!!
the beautiful was to save by name if I rename the block is always the same but with the name changed and if I change that one!
I always do this:
when I'm inside the block, to go out and rename I write the command: amrefclose
Well, before I get out, he lets me rename him.
saveblocnome command, only inside the editor blocks as already said tristan.
Yes, but it's hard, I usually work locally because I need to see what's "below". . .
in the local modification that command is not allowed. But I don't think you realize you're constantly saving blocks, there's no alternative.
