"save and sost component" command does not work
  • Thread starter Thread starter Giancesa
Giancesa
I have the version 2018 of inventor and often happens that the command "Save and Sost. Component" does not work, a message "impossible to save and subt. component" appears, I do not understand the reasons, also because I have always used it since this command came out and never gave me this problem. Thank you.
I tried to change my mind, but it doesn't depend on that. I'll tell you more, I did the test on the last file together where I encountered the problem, and now I don't do it anymore, in the sense that I tried the command and now it works.
In fact it is not a constant, sometimes I have the problem other not.
I don't know, that the problem is connected to the vault? to the file I tried I checked in-out.
I and my colleague had the same problem (sometimes it goes no) with the update iv2018.1
the thing has been resolved with the update iv2018.2
Excuse me again. I installed the update 2018.1.2 but I didn't install the 2018.1, does something happen?
Does 1.2 include down 1 or should I install 1.1?
If the answer is yes, then should I reinstall the 1.2?
In essence, should updates be installed in date order?
thank you and excuse me but I am a little ignorant about these things, besides I trusted the desktop app that no longer works. the problem has already emerged in the Autodesk community but there is no answer to today in this sense
