save files in previous versions
  • Thread starter Thread starter ance
ance
I would like to know if there is a way to save a file in previous versions of sw as per autocad.
there is no system except the passage for neutral files (step, iges, parasolid) with the consequent loss of all native info.
this applies to all parametric cads, not only for moneyworks.
sin, I hoped there was a way in how home I use the 2008 version and at work 2009
thanks for the answer
...but maybe at home you can install the same version with the same license,
ask your supplier or expect confirmation from forum bosses :d
la top ten da solidworks world 2010
results from the 2010 top 10 as they stand feb. 1 --
1. sw should cleanly uninstall itself
2. increase stability
3. file compatibility between versions
4. better utilize all processor cores
5. on the fly equation in dialog boxes
6. allow more types of assembly features
7. graphical map of references
8. option to dangle children instead of deleting
9. exploded views for weldment parts
10. simplify video card requirements
the 2: to the face of the decantated stability of the program by retailers and to confirm the problems we had.
the 3: having the ability to save in a previous version is a real necessity of the market. If the emgine is parasolid and the emgine does not change, it is not explained why it is not possible to save in a previous version even with a possible limitation to the feature tree in some cases. the only explanation is that there would no longer be an obligation to maintain the mutual chain of contractor-supplier upgrades as already happens for autocad. in fact we have small suppliers and also customers who still use autocad 2000 and ask me to have the dwg in that format. . .
to me the dealer always said that you can activate the same license 2 times, once for use at work and once for use at home. in fact at the end of the installation asks you where you use the license. since then usually the license is of the company it is necessary to have the written blessing of the managing director or the owner.
Yes it is correct (it would be mostly up to use on the notebook when you are out always for your company.. ).
clearly you can not use them at the same time, but I think no one is still equipped with ubiquity:biggrin:.
Mar
