solokite
Is there a possibility to save the jpg to white sondo having customized environment color in 3d?
albe grazi, I had thought about doing the macro of the same component but I have to do 3 img of the same mathI have always changed the color scheme (black on white) before exporting the image.
once made reprint the custom color scheme.
You can also make a macro.
yes ok but after the name I reset the custom backgroundmake a macro that stops when entering the name of the jpg file, so write by hand the name
Record the macro leaving the jpg file in the folder so that the "overwrite" is also recorded. if the file is not present then there is no problem, the macro will work the same.for the first image the macro works for the other "I lose the macro" because it asks me to overwrite the name...how can I do?
ah nothing I put my soul in peace; I did another macro to change the environment appearanceRecord the macro leaving the jpg file in the folder so that the "overwrite" is also recorded. if the file is not present then there is no problem, the macro will work the same.
then obviously between one execution and the other will be your care to move/rename the file.
