save individual components in step from a set
  • Thread starter Thread starter mulder71
mulder71
hello to all, my question is as follows: in soloworks 2019 is it possible to save in step so that all components of the axieme become single steps? I don't want to save all the assembling in step, that ok, but all the components individually without having to save them to one by one.
Thank you all.
at the reopening of the step file, try to control the options. If you have selected "import together as parts of multiple bodies" you will have a unique set with all bodies of the parts.
I have the following settings. sw2020.
thank you for the answer, but I think that option in 2019 is not there, because I find nothing.
you don't have to worry about importing, but exporting.
when saved in format step o simili you have to open the options screen that you find below.
then how to open the step depends on the program and the setting of the receiver
In fact, when I save with the step name, options, there are no options that allow me to save the components in many steps, but only saves the assembling in step and comes out a single file. Unfortunately, those who have to receive it want the individual part in step, but I should do it to one by one and are about 400... while in iges it allows it
Put the options screen, which I don't remember.
who receives the file with which program opens it? Are you sure it's not your cult problem?
Of course, saving the individual files doesn't make any sense because they're not connected to each other, and the recipient has to remake the axieme.
disabled the 3dinterconnect?
the receiver wants them single, the assieme has it already has it not to return it
I'm sorry to arrive: I don't know what program opens it with, I interface with a person who is not a designer and must turn it to a third who will have to make a quote that I don't know;
I don't know where to look for setting problems;
is not a connection problem of individual files, the recipient has the assieme but wants the individual steps;
the 3d interconnect is disabled
When do you care how it opens?
if you do not know what program is open it is impossible to understand whether the problem is in your export or in the import of the customer. It is essential to define the opening program.
if you want to export the individual upload files to task scheduler and launch the export while you work on another or while you are on break
thanks as always for availability, if I open it I find the files as imported, but tell you with what program the customer does not know exactly.
the idea of the task scheduler I never used it but it is to try, even for the future.
Meanwhile I convinced with whom I interface to use iges, these sw me save them in many single iges, which is how they would like them in step.
Thank you very much
Here I am, when I create a step as you said, I have options, and so I did, I saved everything in my pc, and then I sent all the individual steps to the customer.
thanks as always.
