save part/axis name and associated design
  • Thread starter Thread starter ConfaMiky
ConfaMiky
Good morning to all,
I would like to be able to save by name, or use the command make independent with a part/axis that already has its own table setting and automatically copy the table. Does anyone know a way to do this?
at the moment I save by name or independent rendo the part, then I cover the design, I give the same name of the part and I change the reference. Is there an alternative method?
Thank you very much
try with the pack&go by popping out that you want to copy even drawings. you can also change the name of all components or just some
but doing so in the axieme where it is inside the particular remains the old part or the new one saved with the pack&go?
if you make a pack&go of a part and renounce it in the axieme remains the part with the old name
...and yet the old together contues to point to the old components always and anyway
However, the old team always tries to point to the old components and anyway
If you do the pack&go of the only part it is right that it is.
if you make the pack&go of the assieme the parter should be renamed in the pack&go window or the reference of the file that must have a different name should be changed, otherwise the last address you have in memory.
It may be so, but I personally never had a problem when I save a job from one position to another. However, I'll organize the works with all the files inside the folder, except for some library components that always remain the same. Of course it is that by doing so I could lose some space, but given the dimensions of today's supports I think it is totally influential. I've never had any problems even copying the folder directly, manually without the pack&go, as when pointing to one or another automnete takes the internal reports to the folder.
