save table with multiple sheets in dwg
  • Thread starter Thread starter dicifa
dicifa
Hello, girl.
I have to create tables formed by multiple sheets....with save by name I can save the tables with multiple sheets in dwg at once only but the only thing I don't want is that the code is xxxxxxxxxx_foglio_1, sheet_2 and so on for each sheet, but it creates a single file for sheet. do you not know if you can do as when you export the tables in pdf that saves them in a single file but with multiple pages?
I just tried and it would be perfect!!! In fact in the bottom left I list all the leaves and so I manage only one code...... I saw that the inventor dwg quietly opens it also autocad. only thing is that it has the white background....
I don't understand. the sheets divide you if you carry out in dwg; if you save in dwg (instead of idw) you have the table equivalent to that idw even if you open it with autocad. or at least to me it works so, just tried out by curiosity. . .
recap... but I explained badly:
If I have created an idw table with 10 sheets and carry in dwg he creates me 10 files of autocad with the same code but with at the end sheet 1/sheet 2/ etc....if instead save the table idw in dwg of inventor creates me a single file but inside I have the 10 sheets (bottom what they select the sheet that interests mevre)...the difference is that if I launch it in the second guess
for the background just set the color on autocad (instruments>options> drawing >colorifoglio/layout)
to open the dwg from autocad button dx on the file>property>open with: change
if you look in the exported file you bang everything on the model space, and then one table at a time; sel file saved the model space is empty and the tables are on various layouts
Bye!
Bye!
but there is no way that when I save it in inventor's dwg and I open it with autocad automatically the background comes out already black as in normal rescue in dwg?
relative to the export that happens in different files for each drawing sheet, are there options to convert each sheet to a related layout in autocad? without doing it manually.
Further problem is that by reopening in autocad views some views and quotas are stretched or moved from their original location.
Put your heart in peace before you can get a perfect export, you'll have to make adjustments.
Unfortunately they are things that do not have a standardized path, it is to try and try again.
I have a pretty hard customer to please and I've been honing export for him for years.
