save with table name loses references
  • Thread starter Thread starter tecnicoSIP
tecnicoSIP
Hello, I have a problem with the sw boards, when I save by name a set or a part and I carry behind the table, it 90% of the times loses me all the quotas that become green and are disconnected.
Am I wrong something in the simple "replace model"? Is there a way not to let them lose at least the part that remain unaltered in the drawing?
the replaced model must derive from the existing one.
This means that it must not be geometrically similar made ex novo, but that it must be a change of the previous one.
It is true, saving by the name of the usual model still manages to lose my quotas.
if you can attach the starting file and the one saved by name and relative tables
Unfortunately I cannot attach the boards, the procedure saves by name draft- replace model is the only way?
There's another
make a copy of the drawing
when you open it from the solid menu (so not from explorer)
when selecting the drawing at the bottom right you find the reference button
click and open a window with the reference of the part
double click on the name of the part and allows you to select another
now you open drawing
