Pablo
Excuse a question.
according to you which logic uses swx in a part of welds when using the command saves the bodies?
Since intelligently swx creates
folders for
different types of bodies - identical to each other - why then when I go to save the bodies does not propose me 1 name for 1 group but proposes me 1 name for each element??? with obvious coding duplication for the same item? ? ?
As it is essential to have a well defined file code for each piece, in my file management it would be very useful to make each member correspond to a code assigned by me. according to you it is possible using the properties of welding? the command saves the bodies has the inconvenience described above. .:frown:
I hope I've been clear. .
