scale object in precise custom sizes (2d)
  • Thread starter Thread starter dave90
dave90
I need to scale an object, some sort of "bastone" like this:
21507.webp(very approximate, but it is right to make the idea, it is bad I know :d )
As I said, I would like to scale proportionally, with la x definita da me, and then y adapts accordingly. .
is a 2d object formed by lines and especially spline. looking on the web I read that many first form a "block" of the object, and then scale it. I created the block, but I have problems climbing it.. I can't give him the exact size of the x I want. .
If for example the x of this object is 90 cm, and I want to scale it to 60 cm (with y always that you have to adapt) , how can I do?
I thought of using the technique to draw a straight line of 60 cm, and then to indicate that the object must scale it as the measure of the line, but I don't know how to do it:( kindly, do you enlighten me? Thank you very much
autocad 2014
Scale tool: reference option; select current point (or measure); select point (or measure) new.
when using a command read what is written in the command bar (if it is not clear how a command or its option works, a vote activated the command press f1 and will open the leash to the relative page
creates a 60 long line
command scale
select the stick and press Enter
on request: select base point select the first end of the line of 60 cm
type r for reference
first select the initial point and then the final point of the stick and, consecutively, the final part of the line of 60 cm
