strudel
Hello.
do you know if you can set the line scale by default?
and can you use different scales for 2 layers or types of lines?
and such scale can be set as a record?
My problem is that every time I insert a line in the axis layout (point draw) I always touch the line, so I should be very comfortable to set a default scale (different magari per layer or line type) and maybe to define it annotative so that to change the scale of the design the line always shows me equal.
Thank you very much
Thank you very much
