scale parts and surfaces
  • Thread starter Thread starter totinaples
totinaples
Hello everyone, I have a small problem in the use of catia.. .
I downloaded a bearing to insert into a product, but to adapt it to my product that has different sizes I would need to scale it.
So I downloaded it first in .catprod but I couldn't change its size in toto, i.e. I couldn't resize the whole product together.
I also downloaded it as .igs but nothing.
Can you do this? Can you help me?
thanks in advance
What do you mean to download in .catprod and .igs? did you try to climb it in the partdesign module?
I mean I dumped it from the manufacturer's website in those two different formats
in igs join the surfaces and create a solid, made this in part design steps as you want
Thank you very much for the answer.
the fact is that my product is a derivation from an image so the measurements are neither accurate nor consistent with the order of magnitude of any bearing. I can of course easily change these measures. I was interested in resize just as better knowledge of catia.. I guess I wanted to know how to do something more... but if you can't do anything.
thank you anyway!!! !
transforms the product you downloaded into one part that will contain various body; to do this there is a specific function (which I do not remember now in which curtain is located but is easy to identify).
Then, in the created part, use the "scale" function that you find in the "transformations" shovel.
we waved
we waved
Thank you and this is what I needed!! !
