scale
  • Thread starter Thread starter CAROLINA
CAROLINA
Good morning.
was building the state of fact of a house in the 1970s.
I have difficulty in making the stairs whose rise varies and however it is not the classic of 17 cm. It seems to me that set with mathematical formula from revit.
As I can do......... because in doing so the stairs do not come to me to the planes being less the n. of rise and higher than the canons 17 cm. the raises themselves.
I can intervene on the formula, but how? ? ?
carolina
disability formula and act on the parameters maximum height raised and minimum depth peeled, in the properties of the scale; in this way revit architecture will work to approach as much as possible to those values. Of course if you do two calculations first....
