scale
  • Thread starter Thread starter LUCA_0232
LUCA_0232
Hello.
I am finding a small problem, I normally to change the scale of more identical objects I want to create a group in which I change the scale and change on all the blocks, now I came from a customer a dwg with many identical objects but not rattled and I would put a lot of time to ragrupparli, selecting all the blocks to make a collective scale asks me a point of reference (I can not give it the center of a single jet or
I attach an example1714644566927.webpThank you in advance.
for passages.
1) by the _tjust command select all objects (acad filters only the texts) and the middle input point (half)
2) select all objects and by means of ctrl+1 open the property panel.
3) the pop at the top allows me to intervene on the only circles, in whose properties I stop the radius or the diameter.
4) through the pop I move on the texts and here I change the height of the text. because by tjust I placed it in the middle of the text, the text will climb into the center of the circle (more or less, looking at the image)
I have the lt version not the full and can't use the _tjust command is any other alternative?
I selected an object I did selectsimilar and finally doubled the properties, do you think it is a problem? seems to work, thank you
If you got the desired result, I don't see what a problem can be.
you have found an alternative solution based on the possibilities available. That's the right spirit.
