scaling i- face
TECNOMODEL
I would like to make an i-feature of a logo we use, from time to time we adapt the size to the piece on which we insert it.
I would therefore have thought, instead of changing so many parameters, to insert a scale value to be defined at the time of inserting the i-feature.
I tried to climb a sketch but it doesn't take the scaling value as a parameter to then insert it into the i-feature.
Is that a feasible thing for you?
I don't know ifeature (I never use them), but I had to do something like this: I had solved (so far as optimal) by making a sketch block that I cared from time to time where I needed and if necessary I modified locally with the scale command (which unfortunately does not seem to act on the block once inserted). for me it was a simple cut so fast to do.
It is not a marvel but until it comes to mind better.. .
But with regard to them, I think we can do: Now I imagine your logo as an extruded sketch. in the part from where you extract the ifeature define a user parameter with the scale name and then multiply each share of the sketch for this parameter, so that the scale change everything is applied. at the time of the creation of the ifeature (extracting, as the inventor calls it) you will have a window with three sub-windows: in the left one there are all the parameters that regulate the processing that you want to "extract" and you can bring as many as you want to right: these will then be required at the time of inserting the ifeature.
I hope I got us. . .
I'm trying your suggestion, but how do you multiply a quota for a parameter?
in any way I write the expression gives me error. .
the idea is to parameterize the original logo (if possible, of course. . . )
