scheduling
  • Thread starter Thread starter ing_alberto
ing_alberto
I would like to realize an abacus made in such a way that the characteristics of the tightening highlighted by the brakes:
1.webpwith the characteristic data of the tightening as :
• Thermal transmission
• Solar radiation heating index
• thermal exchange coefficient
• model
• manufacturer
when I make the abacus locks turned out in this position as from photomontage
2.webpI did a test.
the image represents what I get now, the data as:
• type
• manufacturer
• model
but I would like to know what they mean
3.webpI would like an abacus set like this if possible
4.webpI would like to see what it means:
• type
• manufacturer
• model
I'm sorry, but I don't understand anything. where did you do the abacus, in autocad or in revit? the images show both.
There are 3 pictures. one from the revit and two from the autocad. (? ? ? )
and what do the settings of the abacus in revit? can you connect an image of the abacus settings, not only of the result? So what you see is not a common abacus.
Thank you for the answer.... I reset the abacus and it works....
I ask you a further question... it is possible to make a legend of the davanzali.... linking it to the locks legend?
Thank you for the answer.... I reset the abacus and it works.......
for good use of the forum, you need to solve the question and share the solution. In this case it was not clear the question and no one will know what the solution was.
