schema foratura
  • Thread starter Thread starter power23
power23
Hello, boys, as you know very first weapons of offspring.
for you will be elementary.
I have to realize the attached drilling scheme... now I have the holes of the first sx column (in the box). ..how do I make a series with different distances? Q1...q2...q3?
always if serious is the right command.
Thank you very much.
I apologize if I duplicit some posts... but I searched and found nothing about it.
more than using the serial command...with which you move the entity always of the same step, you should use the edit/operation command with the features/copy/setting
in this case you have to repeat 3 times the series command because you can not do in one time a series of elements with different step.
or if one is attached to the series you can make a table series,
that could be good if on those holes there were to be mounted other components the next series would hear the references of the first
How do you repeat the serial command 3 times? !
once made the first series to place the holes at the q1 distance, how do I recheck the first holes (existing) and make the series that will create them in the q2 position?
you can do by doing the series of a series, but I do this system upset because it often goes into conflict or does not update and lose references for subsequent series.
much better the table series.
but doing the series of a series to the second step creates me 4 holes! if q1 is different from q3 it does not work!
Well... because I started thinking I messed up my life until now. . .
operations with features!
No no... I don't exclude it... I'm sorry... great solution.
But I never use it, not for functionality but for habit.
when I can maximise the possibility of using the series, especially in anticipation of future mounts. It's a method I recommend.
you are definitely right in saying that if you have to insert screws or other the added component series is made automatically!
thank you so much to all... I try and the table series is not bad at all.. .especially for screws etc to place then!
thanks to those who responded.
