script polilinea
jim78b
I would like to try scripts, but if I start the command pl or polylinea it is clear that the script ends there!because autocad asks to select a line what I write in the notepad?I would like to pass to tell it width but if there is the selection. . .
when you launch the autocad psyche command does not ask you to select a line at all but specify the first point!
the first point, here I would like to fly over that I immediately intend to set the thickness or width as I do?
after clicking the first point you can give the beginning and end polylinea thicknesses.
don't do... first you have to specify the first point. But sorry, don't you want to use macros instead of scripts?
