script to control constraints
  • Thread starter Thread starter falonef
falonef
in your installation you will find a ds script to control the constraints in the catproduct.
if the constraints are not ok there will appear a message.
in my case, having installed cv5 on the d:\ I find the script under the following path:
d:\dassault systemes\b18\intel_a\vbscript\assemblyconstraints
beautiful this script...maybe you can also assign it to a key:confused:
I saw that there are others in the same folder. apart from "frametitleblock" that serves for the carts, the others use them or you know what they are for? ! ?
thanks for the signal:finger:
Of course you can put it in a button ................... .
in + if you declare the variables dumpfilename and detectiveall you write a file with the results of reading the costrain .....
to create the key you need to create a macro library and insert the macros you want......... then in customization go on macro and you will see the macros in the library you create a toolbar and insert the commands you want by taking also an icon from the list.......... and you put them a day to see them all and the search is made in a way to say little "indecent", cmq you can untie the icon.
it is + easy to do that explain it cmq if you look in the catia help you should find everything.................. :mixed:
Thanks mcbramby. to create the button I managed, but what do you mean by "declaring the variables dumpfilename and detectiveall ". How do you do that? !
you must insert the 2 variables in the environment variables,
start/programs/catia/tools/enviroment editor....
dumpfilename = "c:\costrain.txt" , virtually declare a file where to download the results and then put detectiveall = yes
launches the macro that will write the results in the file of the dumpfilename .
cmq if you enter the macro in change is explained .
Thanks mcbramby...but how many you know:biggrin:
you are a well of information:tongue:
