Matteo2253
good morning to all, I'm just trying with ilogic getting discreet results but I find myself in difficulty with a rule. the problem is this: I have to convert an idw to dwg and save it to a folder, and so far nothing strange. the fact is that the folder varies from time to time, so I used a data input to get a value I need to "build" the path. the fact is that the final folder begins with the value I bet, but then it contains "n" different characters for each folder. I make a simple example:
- 001 gfdfhd
- 002 gffdgfh
- 003 days
- 004 jgoltoj
in practice with the input text coming up to the first part of the folder, which is well defined. the second part instead by force of things I cannot enter it because not known a priori.
Is there a way to use wildcard characters in creating the folder path? For example if I have to save the dwg in the second folder on the list above, I should have a code similar to:
text_immissed = inputbox("prompt", "title", "default entry") where I admit, in this case, 002
path_fold = "c:\windows\" & text_immitted & " [Bleep] "Save the file in the folder that "start with" 002
I'm sure the asterisks don't work, but I hope I made the idea...
Has anyone ever faced such a problem?
- 001 gfdfhd
- 002 gffdgfh
- 003 days
- 004 jgoltoj
