search on google:
“autocad excercise drawing”
and put pictures
You'll find many.
are exercises to take familiarity with the geometric bases of the design, with snaps and in general with the autocad tool.
what you will not learn is the technical drawing (mechanical? architectural? etc.).
google and find a tide. Alternatively you can also invent them: You take a refractive object, take the various measures and make the various views. You can do the same with your apartment/room.
I would start right from scratch or almost, using only the icons at the minimum, i.e. the icons to use are:
- line
- circle
- Cut.
- despair
-equity/offset
and snaps, in
- end
- Yeah.
-treatment
and depending on whether or not they benefit the other snaps
disable all the aid you have here type line and other
because it is beautiful as you move you have the distance and angle
and to draw I would use a lot of the command line (if you can activate it) but as a student you can have autodesk map and from them you can still do it now but full autocad without map or other application is only an obsolete tecnigraph, if you use as a 2012 autocad I see you have the command line.
starts using the simplest things:
command> line
From the point... choose the point
to the point
here at this point you will have a horizontal line of 10 video units, and from there with fairness choose es 0.3 you will have designed two parallel lines that in theory could be a wall, etc etc etc etc.
