Giacomo Lepore
Good morning to all,
I need to cut a flat test for a traction test from a thick sheet up to 6mm. cutting must be done online, in a sheet metal production plant. I had thought of a laser or plasma thermal cut, but I'm afraid the thermal alteration of the material could be significant. Alternatively, you can use a shear (shaped, because the profile is concave) or a die cutting machine.
Is someone able to suggest me some producer to contact on the second street, or for the shears/fustellar?
Thank you very much
Thank you very much
