search not working
Angelo2449
Hello everyone,
I have a problem with this simple code:
Code:
 (defun c:ps (/ str txt1 ed1 pos1 pos2 ang1)
        (setq str nil)
        (while (= str nil)
            (setq str (nentsel "\nseleziona la stringa "))
        );;while
    (princ "\nstr xxxxxxx ")
    (princ str)
    (princ "\n")
        (setq ed1 (entget (car str)))
    (setq txt1 (cdr (assoc 1 ed1)))   ;; 10:00:00    8.25°    129.88°
    (princ "\ntxt1 xxxxxxx ")
    (princ txt1)
    (princ "\n")
        (setq pos1 (vl-string-search "°" txt1 1))
    (princ "\npos1 xxxxxxx ")
    (princ pos1)
    (princ "\n")
    );;defun
the "°" character is not found in the txt1 string (10:00 am 8.25° 129.88°), if I insert the string instead of the variable, pos1 assumes the right value 13, otherwise nil"
Thanks, so it works!
How would you write, the same command that seeks the next "°"?
(setq pos1 (vl-position 176 (vl-string->list txt1)))
(setq pos2 (vl-position 176 (vl-string->list txt1 (pos1 + 1))))
The first line works, the second one gives me error.
