Pal_65
Good morning and thank you in advance.
After so many years I find myself solving a new problem.
I do not use the pdm plm programmes.
in the company we use a networked server to 6 users/licences proe wildfire 4.0.
file opening operation is very slow.
Currently there are in search.pro about 1500 routes/directory of research/project.
we did some tests:
used a standard set that uses files in about 25 paths/directory on the server.
1) search.pro file with about 1500 search paths/directory.
outcome: 1 minute and 15 seconds opening together
2) search.pro file with about 25 search paths/directory.
outcome: 4 seconds opening together
3) copied the entire archive (the 1500 directories) locally, reset the search.pro that points to local directories.
I would like to have advice and comparison from you.
1) Are there any numerical limits in the number of directors to be placed in search.pro?
2) how should the network (servers, network cards, etc) be built to optimize this file search work?
3) other suggestions.
Thank you again.
we did some tests:
Thank you again.
